RE: What's the different between a pusher and puller props?
You can't just mount a tractor prop on an engine that is facing backwards because the engine needs to rotate the wrong direction for the prop. So you either need a pusher prop, which is different only in it's direction of rotation, or an engine that rotates the wrong way, and use a tractor prop.
