On a 3 channel plane you've only got rudder and elevator. I find that you need to feed in a little up when you turn with the rudder.
This is on a polyhedral plane which banks quite readily in response to the rudder.
But then coupling the two together might screw things up if you needed to use the elevator on its own....
