RCU Forums - View Single Post - Duralite Users !
Old 04-15-2007 | 01:36 AM
KC36330
Default RE: Duralite Users !
Duralite's have the 'safe charge system' and if you charge at higher then 400 mAh you'll blow the circuit, they also have a built in balance charger so balancing isn't necessary.
i was having problems with mine dropping to 7.1 under a 1A load and it turned out the connection from my loader was corroded. try the plug from your charger in the load tester and see if your readings change.
kc
