T-maxx Header Pipe ?
If you are running at the 230 mark that is about perfect, if you are jumping above 250 I would say richen the HSN by an 1/8 of a turn and check your temps accordingly. Using 30% nitro is another problem you will have with temps, the higher the nitro content the richer you are going to have to run, Traxxas recommends 20%..
