RE: CPP Tail Motor Problem
Thanks for the suggestions...I'm sure you've hit on the problem...I'll try eliminating the G90 on the next motor...my gear mesh and bearings seem to be fine...I never gave a thought to changing the tail set up based solely on using the G90. Does that cause the speed controller output on the 3 in 1 to increase? Thanks again...
Chuck
