RE: cap 232 help needed
The built-in right thrust should be about right. A little added up thrust might help, and check that all the servos are working propoerly.
If it pulls left when you enter an up line (which most planes do) you may want to mix some rudder with the elevator.
I have said many times before that Caps require a lot of trimming and are more of a 3d plane.
TF
