RE: Tamiya TA05 - Racing Thread
My F103 was taking a beating running on asphalt. So I thought I would get a TA05 and race it, and save the F103GT for carpet.
________________________________
Here is my setup for stock class so far
Motor
Nemesis 540 13S (Cordite Motor)
ESC
Mamba Max
Battery
Max Amps 6000HV
Transmitter
Airtronics MX-3 75Mhz
Receiver
Airtronics Super Micro Receiver 92836
Body
Tamiya NSX
Front Tires
HPI X-Pattern Belted Pro Compound
Rear Tires
Front Shocks
The Big Tamiya Stock Spacer Only
2 Hole Piston
Stock Tamiya Dampner Oil
Stock Springs
Top Location - Inside Hole
Bottom Location - Inside Hole
Rear Shocks
2 Hole Piston
Stock Springs
Top Location - 2nd Hole From Inside
Bottom Location - Outside Hole
Spur Gear
Stock
Pinion
Stock 22T
Toe
Front - Out .5 Degree
Rear - 0 Degree
Camber
Front - 0 Degree
Rear - 0 Degree
Hop Ups
None
__________________________________________________ ___
I will change my setup here as I make the changes to the car.
