RE: Hovering the CP PRO?
It sounds like the the swash plate is not 100% level in all directions. Also make sure sure that the trim settings on the radio are centered. It should lift fairly straight up in the air. The other thing to ensure is that the battery is perfectly balanced from front to back and side to side.
