RE: Azzmans LCG Mid Tank Mod
Ok, I am sketching out the layout of the TVP I am going to fab up. I have decided to go with a 15mm motor/trans drop. I have planned a 10mm extension on the front. Now, that means I can use a rear dogbone in the front, right? I am going to use .125" thick, 6061 aluminum alloy for them. What kind of metal did you use? Am I even in the ballpark when it comes to the design of this? Is there anything else you could tell me about that might help me or prevent a problem that I might run into? Thanks...
