RCU Forums - View Single Post - convert this!
Old 04-27-2007 | 12:38 PM
  #48
CrunchyFrog's Avatar
CrunchyFrog
Default RE: convert this!
It wasn't friction stopping my servo push rods--it was torsion. With inch-thick end caps, the rudder linkage has to line up perfectly--and stay lined up perfectly. Or I'll have to drill out a wider tunnel, which I'm not willing to do just yet.
I've got a stack of dead r/c boards, and a cache of good motors that went with them. I'm thinking of sealing up a few to experiment with "wet" servos.
I guess leaks must be the most frequent problem with wet servos. Plus how do you keep rust at bay? And since I'm sealing in hot glue, I wonder how to keep this improvised casing from melting onto the shaft and paralyzing the sub when it's halfway across the pond.
