RE: LIPO battery charger question
the TP does have a data port for balancing, but you plug the charger into the balancer and then the balancer into the battery. I can still use the same balancer with the AF. My TP is 1 month old and it doesn't have an AC input... And as for the 10 cell charging and the 10Amps, I can only charge my batteries at a max of 6amps and they are 2 cells. I'm thinking I'll probably turn around and sell this charger. I figured it'd be faster or better in a way that I'd be able to use it, but I guess the charger is above me. Thanks for your input.
