RE: RCV Prop and Starter
Hi
If this is a new engine, you may be experiencing problems starting it as it maybe tight and not run in. If possible it may help initial starting if the engine was warmed up by using a hot air gun applied to the cylinder head. Once run in the engine should start using a chicken stick.
I hope this helps, however if you have any further questions, don't hesitate to contact me.
Best regards
Stephanie
