ORIGINAL: GTB
Cool vid. The area where you drift at is way smaller than mine.
What's the setup on your car. i.e engine, pipe, etc.
I'm running an SH.12 with an Ofna X12 pipe. Recently bought a two-speed for it but haven't decided if I like drifting in 1st or 2nd gear. I have all four corners at zero camber, and 1 degree toe-in on the rear.
ORIGINAL: brokespokes31
how are the rpms with those ? high or low ?
Well, for the area in the vid it's about half throttle or lower with small bursts of full throttle if needed.
