ORIGINAL: KGSS28
Thanks Eddie . Are you shure the metal axle will fit inside the with an ID of .236 ? That sounds bigger than the stock ID is . It is a real shame that Ultra RC wont support this product it really does fly very well . I have several contest just sround the corner that it looks like I will miss because I cant get new struts. I know that they were trying to keep the price down but they went to far with things like this landing gear setup and no service.
Thanks Kirk
Kirk,
In regards to your comments, if you are referring to the fact we are currently sold-out of the replacement Evolution landing gear, than I am sorry. We did offer you the replacement Giles landing gear legs which are a little over 2" shorter in length than the original Evolution legs. They will fit and work in the stock landing gear sleeves, however the bolt hole in the top of the leg is not drilled in the correct location to fit the Evolution sleeve. Many have used the Giles gear and simply redrilled the landing gear leg in the correct location. If you are interested in this set-up, email or call us and we will take care of it for you.
Sincerely,
Ultra-RC
Jim Eble
