Mark, what is your weight? I have a heavier Actro 24-3 that may assist in balancing (12 oz motor). Also - how are you accessing your batteries, you pulling the wing? And lastly, what servos are you using? I have this plane and have been thinking of selling it, but may hold off. Thanks.
Joe
ORIGINAL: MarkF
Yes, I drilled out the scoop. If you saw my field I fly at you wouldn't wonder were the wheel pants are. I will put them on when I go to a different field. As far as the equipment goes I used what I had on hand. Maybe $800. worth of stuff. If I were to start over I would probably go with an out runner on a 6s batt. I think I could come up with one that would do 100 mph and cost half of that or so. Electrics are never cheaper. Just faster.
