RCU Forums - View Single Post - EagleTree Data Logger results
Old 05-03-2007 | 07:52 PM
rm's Avatar
rm
My Feedback: (27)
Default RE: EagleTree Data Logger results
I've used the bnb for the last couple years. It's true it can only handle 30v, but the software adjusts the voltage to show 2x which is fairly accurate. It's a nice unit and works well. I just got the eagle tree and have been using it lately. Has a few more features then the bnb, like a calibration feature, better exporting of graphs, but they're both comparable. bnb is coming out with a new higher voltage model, not sure what all the improvements will be. As they are now, I'd go with the eagle tree.
I'll add if your running a 10s pack which is permanently configured as 10s you can only use the micro logger. If your running 2 packs harnessed together then you can use either. The bnb unit came before there were 10s chargers and 10s packs.
