RE: best value eflite plane
i just got my tribute flying and it really does prety good. its all foam, with a real fus and wing with air foil. goes together quickly and fly's almost as good as my flinton 330. it has just a bit of roll coupling in yaw but needed only about 6-7 % on dx7 radio. i am flying with park 480 and 10x4.7 way over powered and the 480 is under proped. so go like the instructions say and run a 450 and evo 1500 3 cell. it will do most 3d stuff or all that i can do with no problem. 350 sq on the wing area and with 480, 2100 common sense batts it right at 20.25 ounces. airframe with everything minus batter is around 13 ounces. the nice thing i like is its only 60 dollars.
