RCU Forums - View Single Post - Prop Stuck on shaft--Help!
Old 05-07-2007 | 09:16 AM
jhatton's Avatar
jhatton
Default RE: Prop Stuck on shaft--Help!
$5 lesson... try more like $17 those bigger props get expensive... What I find works (If you don't have a bearing puller) is to use two clamps and a block of wood... put the block of wood in front of the engine aginst the shaft and put one clamp on each side of the prop, tighten each clamp at the same rate and that will pull the prop without breaking or bending anything.
