pushrod bending
To flex the pushrod tubing supports must move appart which will not be possible if they are fixed. On the diagram I mean that they must move apart in the horizontal axis since any bending will cause the diagonal section to force itself into a more horizontal level which would make the horizontal spacing between the supports longer. Hope this helps...
