ORIGINAL: mtwister
Moki's are straight to the carb from the tank.
ORIGINAL: bubbagates
Guys, just remember, On the OS160 you have the short line between the needle and the carb and you need to replace that one as well. The 1/8th line will be a loose fit so just use some small wire ties on the nipples and you'll be golden
I'm not sure on the Moki's if the line goes directly to the carb from the tank or it's like the OS with the tank -> needle -> carb
Thanks, did not know that
[sm=red_smile.gif][sm=thumbs_up.gif]
