RE: Self build LiPo packs
Found this old post while searching for LiPo pack assembly tips. So, has anyone successfully soldered three LiPo packs in series and what is the best technique? I understand to use a small amount of heat with low temp solder. Do I need to use the silver solder and will only special aluminim flux work? Solder tab to tab and 14awg wire to inout and output tabs? I bought three 4000mah LiPo cells with tabs but have not assembled them yet. Waiting to understand the correct process.
Frank
