ORIGINAL: BillS
Did you fix the tank so it comes out easily?
I have been searching for an air bubble problem for a week and the tank has been out more often than Britney’s panties have been down.
Bill
[sm=lol.gif] [sm=lol.gif] [sm=lol.gif] [sm=tongue_smile.gif] [sm=wink_smile.gif]
I love your analogy
. I took the tank out yesterday replaced all fuel tubing and added foam . I thought the problem would be solved but NOT [:@] . I then decided today to remove the Magnum engine and put on a Os .46 AX engine that I had not run since a pretty good crash last year . The AX has the same problem [:@] . Unless the AX was damaged in the crash it ran real good before but had the same problem as the Magnum . It started with 1 flip even though it had not been run since fall of last year but when throteling up there was bubbles and the engine quite . Actually the tank is harder to get out with more foam . It is back to square 1 with a different engine doing the same thing unless someone can think of what the H is going on .
