RE: Nitromodels PREDATOR RQ-1B
Here you can see the result of the above process as the Deans connector for the battery and the extension from the ESC, which will be attached to the MAXX Products #1570 universal controller switch, are routed to the front equipment bay under the canopy. This little switch is great as it gives you the comfortable feeling of knowing that you can attach the Li-po and then use the switch to "turn on" the ESC.....makes sense to me!
