RCU Forums - View Single Post - I need help on a scratch wing I'm doing
Old 05-24-2007 | 11:17 PM
fw190pilot
Default RE: I need help on a scratch wing I'm doing
You could also clip the front corner at about a 45 degree angle and move the front bolt back a little. Put a carbon doubler underneath in that corner should be plenty strong. If you have enough wheel spacing could even move gear in a half inch or so on each side would have to cut less off the corner.
