C/G is 4 1/2" from the leading edge at the start of the wing saddle.
The following throws are recommended for early flights.
Elevator- 10 to 15 degrees
Ailerons- 10 to 20 degrees
Rudder- 15 to 25 degrees
Nosewheel- 10 to 15 degrees
Make darned sure the elevator servo cannot rip loose. The stock mounting
is not
satisfactory. The servor comes loose, and the plane "lawn darts" into tiny pieces. [
Don't ask how I know this. Cyclic Hardover's plane was lost too, both on maiden flights. [X(]
I ended up actually bolting the servo
through the elevator so it cannot possible come loose.
FBD.
