RCU Forums - View Single Post - Finally
Thread: Finally
Old 05-27-2007 | 04:20 PM
ehroof
Default RE: Finally
did you break it in? if so, lean the high end and low end needle a 1/4 turn and see if this helps you out, if you find it still dies than raise the idle a little by using the idle screw with the sping on it, turning clockwise
