RCU Forums - View Single Post - Hellfire Steering Problem
Old 05-27-2007 | 06:39 PM
aer-wubby's Avatar
aer-wubby
Default RE: Hellfire Steering Problem
Yeah, your servo saver was probably loose. I would personally get a better servo as a first upgrade.
Take the servo horn off the servo, then set the trim to zero on the radio (making sure the receiver on the hellfire is on of course). Re-install the servo arm so it's 90 degrees (see the picture below). Once you done that, start aligning the wheels making sure to give some toe-out on the front.
