RCU Forums - View Single Post - Separates Set Up Help !
Old 05-28-2007 | 07:49 AM
sdmahr
Default RE: Separates Set Up Help !
Truglodite/Georges,
Thanks for your inputs ! ! !
Yes, I believe the ESC is setting its initial point before the TX/RX/Gyro is ready and stable. This is causing me all kinds of problems in trying to get set up. I did get the ESC to arm where it was stopped at full left and wide open at full right. At the mid-point, (neutral), it was, well, half speed. (With trying so much I can't even remember how I did it.....but..) That was great but at mid stick it would have spun in circles on the floor if I went to set it down ! So, I then went in and adjusted sub-trim until the prop was barely spinning at mid stick. This seemed close, but because subtrim was adjusted so far to get it stopped at mid-stick it seemed the RVU (throttle to rudder mixing), had to be adusted to the max in order to even be close.
So, closer but still not there yet. The power switch to the ESC may be the ticket here.
Keep the suggestions coming. I can't be the only one who has made this change !
