RE: Speed 600\ESC\Cavitating problem!!
Hi Mepete,
How big is your hull?
What 'this should work' prop, did the LHS supply?
Normally, a 600 motor on 6 cells is a rather tame set-up, seven cells would be better.
The prop we use on a 7 cell set-up is a Graupner 37,5K two bladed hydroprop.
Could you post some pics of the boat, seen from the side, so we can see the propshaft angle?
Regards, Jan.
