Unfortunately, many kits manufacturers assume you are a veteran kit builder. Most of the top brand kit manufacturers also include detailed dawings and assembly instructions. You may be better off putting that kit to the side for now until you are more experienced.
Top Flite, Sig, Goldberg and many, many others do a very good job with plans and instructions. You might want to put "feelers" out here on RCU before you buy your next kit. Previous builders can tell you if it's instruction are complete or for the more advanced builder. People here may also be able to walk you through the build if you have questions. Help is usually just a question away!
Good luck!
Rod
