RE: Intermittant problem for T7CAP
Hi Bax,
I took your advice and ran the simulator while also running 4 servos via a futaba receiver. I traced the problem to an intermittant connection on the cable that came with the flight sim. The servos kept on ticking the whole time without a flinch.
The only other possibility for my problem was that the square micro connector in the Tx was a problem but I could reproduce the problem on command in the cable "a ways upstream of the connector" while hholding the connector so it didin't move when I wiggled the wire. I'm sending the cable for exchange.
Can you tell me if the square micro connector and it's mounting in the Tx are pretty bullet proof? Just wondering for piece of mind.
Dave
