RE: not engage engine?
Craig,
no it does not function as a filter at all nor a primer. It only functions as a check valve, not allowing pressure back out of the tank when you let of the throttle. The intention is to keep consistant pressure in the tank when the tank get to half full it wont lean out the engine... read the thread it will explain all..
