RE: Shuttle Plus
Is the RPM too high or too low?
Basically the same curves from your ZX should work on the Plus. Same dimensions etc. Just the 37 will put out more power and possibly a higher RPM.
What is the pitch curve degree amounts that correspond with the percentages you listed.
Thanks!
Jeff
