RCU Forums - View Single Post - Please help!!!! my Li po pack won't charge
Old 06-07-2007, 12:00 PM
Fliprob17
Fliprob17's Avatar
Default RE: Please help!!!! my Li po pack won't charge
ORIGINAL: cbreeze
I did order the USB link. Between flights, I just turned everything off and did not remove the battery.
With the pack connected to the ESC still? That is most likely your problem. Just because everything is off, does not mean that the system will not drain the pack when it is connected, very slowly, but it will still drain it. Always remove the pack if the plane is going to sit for a while to prevent it from draining.
I don't think the Triton 2 will allow you to recover packs. At least you found someone to help you out. Personally, I would not charge as a NiCd.
