Well the Seawolf SB1 is in progress. I just got my 2 ch 49mhz radio to work. The radio runs on 4.5 but i hooked up a 6 volt batt to it. Seems to run fine got about 1000 rpms more
. I jsut tested my wally sub motor for the tx(whistle)[X(] whoo lots of umphh behind that prop. Now im going to need to get the hack saw and cut off the nose cone of the wally sub and its tower. I also am going to extend my hull somehow becasue the shaft sticks out about 1/2 after the end of the pumpjet or wannabe pumpjet. Otherwise it seems to be going ok i have to hot glue this holes shut because i made some mistakes and put extra holes then i will do a motor and wtc test plus a depth check. Then i will need to ballance it out. Thank god tommorows friday
