RE: 2.4 Spektrum Binding Issue
Luis,
You plug the little gizmo into the battery port of the RX you then plug the battery into an unused channel . The lights should start flashing. You then turn on the TX while holding the bind button on the back of the TX to complete the binding process. Make sure the orientation of the gizmo and the battery is correct.
Good luck.
jef
