RE: Show us your Beaver!
Drew I built the Unionville beaver several years ago and found it to be pretty easy to build. There is plenty of help here if you have problems. go ahead get your feet wet. The biggest problem would be mounting the floats. The wing is straight <no taper either way> so it is easy. Hope this helps. There is a lot of satisfaction in building your own, instead of buying an ARF. Rich
