OS 46 SF bearing removal
I'm changing the bearings in one of my OS 46 SF engines. I am at the point where I need to remove the rear bearing which is the last step. I am stumped as to how to get this thing out. There is no exposed portion of the bearing that I can push against from the front(through the shaft opening), and there is nothing for me to pull against from the rear. I know that there must be a trick for this so let me know...
Jeff
