RE: Pull start issue
...or the one way bearing in the pull starter is dirty. If the engine is running fine I say its the bearing. Take it out and soak it with nitro cleaner, then wd40 then grease her up. Also clean the inside of the pull starer with nitro cleaner. Should start fine after that.
