RCU Forums - View Single Post - carburetor problem?
Old 06-11-2007 | 11:52 PM
bluecaka69's Avatar
bluecaka69
Default RE: carburetor problem?
if you blow on the line that goes into exhaust pipe does fuel travel through other line into carb the carbs are so small unless you are running without an air filter I dont think your carb is clogged you may have a massive air leak somewere so try blowing with your mouth first and see what happens
