RE: Mid-air this weekend. Anyone to balme??
Wow.
I just can't believe some of these 'answers'. If I had been involved in such an incident, well, unless I had been doing something extraordinary, or profound, I would simply relay regret that it had happened and let it go at that. Mid air's happen, and as I said, since this was unintentional, hey.. no one turned on a third transmitter to cause inteference did they.. blame can be placed in that situation... but no, this was simply a mid air collision.
Try it some time.. fly your plane and try to watch someone else's at the same time. Then try to find your plane again.. unless you have one eye that focuses to the right and another that focuses to the left, then you probably cannot see both at the same time. Then if you do look at the other plane, plan on using that plastic bag you put in the fuselage to clean up the mess as your plane smashed into the ground.
Nope, no one is to blame. These things happen, and are truly unfortunate, but they can, do, and will happen.
Someone's 1-2-3 step to blame is way out of line here and is in the least, absurd.
