RCU Forums - View Single Post - MVVS/Evolution 45gx2 loose bolts
Old 06-20-2007 | 04:51 PM
ggroyal1's Avatar
ggroyal1
Default MVVS/Evolution 45gx2 loose bolts
Hello Pe,
I have a 9 month old 45gx2 that runs great and have had Zero problems. I do have a question about loose bolts and nuts. I have been using standart blue medium loctite. The muffler(wrap around) has two bolts that loosen after 3 or 4 flights using standard blue loctite. I found some high temp(450 degrees F') medium strenght blue. I applied it to the muffler bolts and the two ignition bolts. I do not use RED loctite. I read the forum often and I am glad you help Evolution owners as well as MVVS. I spent a week in the Netherlands and everyone seem to be nice like you. What do you think about using Loctite. I am going to let the new loctite setup for a couple of days before flying again. This is my first gas(Hangar9 Cap232) and the Evolution/MVVS 45gx2 engine matches perfect. Thanks again for all the help for Evolution owners.
George G. Royal
Atlanta, GA USA
