RCU Forums - View Single Post - Lite machines TR gearbox defect
Old 06-24-2007, 07:58 AM
ViperRR
Default RE: Lite machines TR gearbox defect
I never used the stock box (older or newer type). For my 120's, I use chopper-1's that will work with stock wire drive and belt drive and totally indestructable, or a BT crazy case which only works with the belt drive. Chopper-1 no longer makes his. Maybe you can post in the FS/Wanted forum. If you want to convert to belt, BT's is also tough to break and he still sells his.
