Old 03-07-2003, 07:31 PM
onewasp
Default Do Rhom Air's spring down?
I would go to BVM and also check out Robart. Robart have well engineered products which are well executed as well. BVM may have a set specifically engineered for the F-4.
I particularly like the Rhom feature of no up lock as it allows you to stall the gear into foam rubber, the result being that vibration induced wear is about zero. You can probably do the same thing with Robart by selecting a set which "over rotate for your application and therefore will stall before they reach lock. Just one man's preference.
