RE: Model Shipways 'Miss Adventure' 1:6 kit
Hi,
I just happen to be working on the Miss Adventure as we speak. It's a pretty easy boat to build and very complete. From the pictures, you can see how it goes together. But be forewarned, I deviated from the kit instructions in one big way. The kit tells you to plank on frame using the wood strips (I don't know the name of the wood) right over the frame. I know from experience that this wood would not do a good job to be a single layer on the frame, so I'm using it as the second and final layer. I decided to cover the entire frame with thin sheet balsa, sand it down nice and even on the outside, and Z-poxy the entire inside to make it waterproof. I then used the strip wood over the balsa, making it nice and even. I've got a few more pictures, but I need to make another post.
All for now,
Brian
