RCU Forums - View Single Post - problem with 9zap (two elevator servos setup)
Old 03-08-2003 | 09:31 AM
3dmaniak
Default problem with 9zap (two elevator servos setup)
Thank you all i will try the several setings that you have proposed me and i will let you know what hapend .
>> mglavin
If you have an early 9Z, the software suffered from a slower frame rate. A slightly but notable mixed/slave servo was not uncommon. Later TX models addressed this issue.
Michael
my zap9 is one of the first models and i think that this problem of the software is not the only one if you have to use several mixed/servos .I have suffer a lot of times trying to setup radio gear to models that required more that 3 servo for flaperons and speed breaks .
