RE: F27 STRYKER -Way Past the Limits Part 6 -Go deeper in to the Dark Side...
Yes I did the same as yours so far. I will add the shorter ones later. I am ready to cut the TE for the balsa piece to hinge to. How wide are your elevons? I mean from LE to TE. I looked over our conversation and could not find it. Also did you have to do a bunch of sanding to get the thickness right from inside to outside?
