RE: 10 ft PC6 Turbo Porter
Fiberglassing the fuselage sides. I ran out of .7 oz glass and had some 1.4 oz cloth so I used that on both sides.
You can see the low spots on the top of the fuse that will get evened out with a high build primer. I didn't want to sand too far down and risk going through the glass.
Put the wings on after I got done with the flow coat/sanding and glued the tail group on
