RE: JR Programming Question
I'm not quite sure what mix 1 and mix 2 are, and you will not get satisfactory results mixing aux 5 to aux 2 as suggested previously.
This assumes that you have already programmed flaps using the 3 position flap switch in code #66 and disabling the left slider in code # 17.
To program your speedbrake to extend when selecting the land position on the flaps switch first remove the servo arm that actuates the speedbrake
from the servo because the next steps may overdrive the linkage. Using this program, you will only be able to move the speedbrake using the 3 position flap switch.
1. Disable the mix running the speedbrake with the left slider
2. Disable aux 5 using the code 17 function
3. Turn on the receiver and replace the speedbrake servo arm back on the servo so that the linkage is in the retract position. You can fine tune this using sub trim.
4. Find an unused mix and activate it using #6 (flap) to #10 (aux 5) hit enter
5. Move the three position flap switch to the mid position and hit store (under offset)
you should see the same value set in offset for mid flaps as set in code 66. This defines the kick point for activating the mix.
6. Move the three position flap switch to the land position and using the + button enter the value that moves the speedbrake servo
the desired amount to activate the speedbrake. Use the turn button if the servo is moving in the wrong direction.
