my tt-01 chassis specs:
Tamiya tt-01 Nismo Coppermix silvia kit
Tamiya ball-bearing on differentials
Boaca ceramic bearings on drive axle's and shaft
Tamiya carbon upper frame
Tamiya front and rear swaybar
Tamiya upper adjustable arms
Tamiya adjustable tie rod ends
Tamiya blue foam bumper
Tamiya aluminum racing steering set
Tamiya aluminum steering link
Tamiya aluminum toe-in rear uprights
Tamiya aluminum bumper stopper
Tamiya metal motor mount
Tamiya ball differential front
Tamiya locked stock diff rear
Tamiya aluminum clamp hub adapters
Tamiya universal axle shafts front and rear
Tamiya TRF dampner set with yellow medium springs front 30 weight oil, and AE factory team blue 18lbs rear with 30 weight oil
Tamiya evoIV prop shaft with Aluminum prop adapter front and rear
Tamiya stock 61 spur gear with Robinson Racing 22t pinion gear.
Square Racing Front carbon chassis stifner
Square Racing Rear carbon chassis stifner
Square Racing servo to steering turnbuckle link
Square Racing rear carbon bumper plate
Square Racing carbon shock tower stifner
3 racing aluminum servo mount
3 racing aluminum battery post
3 racing aluminum upper arm mount
3 racing motor heatsink w/ fan
GPM lower aluminum arms front and rear.
GPM aluminum front knuckles
GPM front aluminum bulkhead
speedway pals 37r sliders 8mm front and 10mm rear
HPI A-type drift radials
Team Novak GTB/Velocity 6.5
Hitec 965mg coreless high speed servo
Spektrum sr3001rx pro series
